IH 3 point 3 bottom plow
BLS
10-02-2002 09:02:59
Trying to identify model number and find source of points or shares for this plow.
Beams are 12 " apart so I assume that plow bottom is a 12" plow.
Two beams are stamped with 5933R1 and a shorter beam is stamped with 5932R1. The moldboards are stamped with SA6104 SC. Has a screw adjustable crank for side to side tilt angle.
Missing points I am trying to find are approx. 6" long, 4-1/2" wide at widest point and have 2 mounting holes 2-3/8" apart.
JIM
10-16-2002 10:03:55
 Re: IH 3 point 3 bottom plow in reply to BLS, 10-02-2002 09:02:59
HI, sounds like a Canadian Ace bottom plow.
I have points for it. The points are 7, 8, or 9" wide.
Jim in Ontario
BLS
10-21-2002 19:09:49
 Re: Re: IH 3 point 3 bottom plow in reply to JIM, 10-16-2002 10:03:55
I saw your response on "Yesterdays Tractor Forum". After I posted my
inquiry, I did find on the back of the moldboards what appeared to be in
faint paint "Made in Canada", so you may have identified it correctly.
I have had a heck of a time trying to identify it. Can't find anything
on Canadian Ace bottom plow either.
So you have 3 different size points? Which makes the most sense for use
on it. I don't have any of the points to be able to get the correct
dimensions.
I am in Western NY, south of Rochester. Any further info would be
appreciated
JIM
10-16-2002 10:00:42
Jim in Ontario
