HI Forum Sorry to hear around all of the people getting hurt . First; Thanks to the people who are in the Fire and EMS etc. , I was there for about 9 years. Sound like you guys have a good sence for learning good for you , there are a lot of Dept. that just don't teach to learn how to learn. A club if you will, place to go. Just a couple of notes: Garden tractor are good for rolling to . Double your speed and you are 4 times the chances of a turn over ( to the side ). If your pulling watch the clutch, if you are going up hill on a hard pull and get stuck. First thing you wish to do is push in on the clutch, better let her spin first ( make a hole) she can flip that way to. All ways have good brakes, I can not tell you how many time, I would have got hurt or worse if I would not have good brakes On my tractors, THOSE INCHES CAN MAKE THE DIFFERENTS. Tire pressure too low or too high. Hill sides get the hole filled in. When working on hillsides watch the upper tire more than the lower, hit a hill ( ants ,ground hogs & etc.) and over you go. Not that a low spot will do the same but is normaly just about the time she start to go over your through the hole and your back to normal grade. After 20 years of running WD's layed one over last year, I was lucky so was the tractor. I got off right before, but all most got it when she was still running on her side. Moving dirt and was too tried, but only going to do just a little more. That little more was all most the end. Came off of one dirt pile and up on a other and over see went. God Bless All !!
Have a Good One!! Teddy ( Punchie )
