Ford Three Bottom Plow
Tom-TX
10-03-2002 21:36:37
Am looking at an old breaking plow with 3 14" bottoms. Ford metal label says IOI then says Io458 and Serial no. 6684. Wings have number 10440 on them. Needs new wings, slides, shins, and points. Are parts available? At a reasonable cost? Do these model and serial numbers make sense to anyone? All help appreciated.
Scott
10-04-2002 17:30:54
 Re: Ford Three Bottom Plow in reply to Tom-TX, 10-03-2002 21:36:37
Jerry is correct, this is the best plow to have, parts are also available from your local New Holland (Ford) dealer at competitive prices, there are 2 different styles of landsides, one has 2 5/8" bolts and the other uses 1 5/8" and 1 7/16 bolt to hold the on, check yours before going for parts.
Jerry D in NC
10-04-2002 03:35:16
You have a 3 bottom 14" shear bolt plow made from 1959 until at least 1981. If it is red it is 59-62 and blue from then on.
As for the parts
Agri-Supply handles all of the parts you need as do most farm supply houses. You could not have a more common, "parts are available" plow to own.
19092 EA F 104409 MOLDBOARD 14 X 5/16 52.49 19154 EA F 104356(100600) FRONT LANDSIDE 15.49 19153 EA F 104355(100601) REAR LANDSIDE 15.95 19035 EA F 104403 SHIN 12-14-16 X 5/16 7.99 32009 EA F 14-4RS (STAR) Rock Share 8.49
BTW They call plow points rock shares.
ShepFL
10-04-2002 20:22:11
 Re: Re: Ford Three Bottom Plow in reply to Jerry D in NC, 10-04-2002 03:35:16
How 'bout cha Jerry!!!
Hanging tough here in FL, just had to say Hi!
