Baler twine and manure spreader beater bars
Michael Soldan
10-06-2002 15:42:48
I had the unpleasant task of cutting several strands (hundreds) of twine off of the beaters today. I used a utility knife and it went fairly well if you like your hands in manure covered string. It was dried though. A neighbour said I should take my propane torch and burn them off it was easier. I'm not sure that would be a good idea. Any thoughts on this quietly kept topic?? I couldn't understand where the string all came from as I never throw bales into the manger with strings on...but every time the baler misses and we rebale a section of the windrow there are two strings getting baled into the bale, I do pick them up as much as I can to prevent this but I guess it happens. This New Holland spreader works very well despite the string problem....Mike in Exeter Ontario
Hugh MacKay
10-19-2002 17:25:41
 Re: Baler twine and manure spreader beater bars in reply to Michael Soldan, 10-06-2002 15:42:48
This problem as I see it is worse than it used to be. To me three reasons:
1. Swaping of land for crop rotation.
2. Round balers.
3. Plastic baler twine never rots.
I was plowing this spring on land new to me. Being 60 years of age I cant believe what I plowed up. I though once only corn stover and small bushes pluged small clearance plows. (Farmall SA) I was wrong, baler twine can do it. You see guys loading round bales twine end comes loose and trails behind, tractor breaks off 30 feet. I have been in several tilled fields this spring farmed by big equipment and guys with even bigger plans. Their land looks like a sanitary LAND FILL site. Mike, this type of farming is going on all around you, and wind can move this stuff. Governments even subsidise this type of farming.
Ty
10-08-2002 05:31:35
I use the propane torch. But I have a Knight 716 Slinger. Only has about 3ft. of hammers. Real easy torching than cutting. Torch, remove, water, done! Takes a few min. Never had a scary moment doing it either.
F14...Gee
10-07-2002 04:40:00
And I thought I was the only one that was fussy about that. I don't have a problem with it in my own hay, as I only feed a bale a day, tops, and can catch any that might have been rebaled.
I "import" horse manure from a friend that has a horse but no place to dispose of the exhaust. After the first couple of loads, I asked her nicely to be careful about dumping the twine into the load as it was a pain to untangle from the spreader.
I'm with the other folks, a utility knife on a SHUT DOWN spreader. I'm big on shortcuts and doing things the easy way, but I'd NEVER work on rotating equipment. And, being a volunteer firefighter, I certainly don't recommend the propane torch method.
Wheels
10-06-2002 20:16:35
I have heard that you should have the beater running slowly while you do this, something about the heat being hard on the bearings on the beaters. I have never done this.
We try to keep the stings down to only a few, This doesn't work well if you do all of you hauling in a single period of time. We cut them when they are dry.
Wheels
Punchie
10-07-2002 04:27:25
 Re: Re: Baler twine and manure spreader beater bars in reply to Wheels, 10-06-2002 20:16:35
HI Wheels
About your first Paragraph SAFTY FIRST, that sounds like an accident , Please don't ever work (mainteinance) a peice of equipment when it is running.
I would cut them off. After I hose the spreader off the spreader after I'm done using it for the season. Greese and cover with used motor oil. Fix any thing that looks out of working order and put away, in a dry place ready to go for spring. If you do put it a way not clean ( we all do that ) they will dry and can be cut off easy enough at spring time. Remember try not to run them if too cold, below 32 chains get brittel and can snap. Also if a freeze is coming make sure she is not loaded.
Just my opinion but why use fire for that , may make a bigger fire ( all fires start small), and cause more of a mess.
Be safe and God Bless!!
Teddy ( Punchie )
Hugh Mackay
10-24-2002 19:37:43
 Re: Re: Re: Baler twine and manure spreader beater bars in reply to Punchie, 10-07-2002 04:27:25
Apparently you don't spread a lot of manure. When in the dariy business I often spread 50 to 60 loads a day for couple of weeks at a time. Cleaning the beater was a daily event. We didn't have a lot of problem on twine, but it doesn't take much on that volune.
Our manure storage had to be empty by end of Nov. and on wet seasons that often required waiting for frost, and yes on ocasion manure was spread at - 10 to -20, didn't like but it had to be done. It was either put it on frozen ground in Dec and have a blanket of snow cover it, or wait for snow cover and put it on top of snow, that I didn't like. For my operation manure was best spread onto corn stubble or stover and idealy plowed or disked in fall. If that didn't happen because of weather stover held it good over winter and manure was effective in breaking down stover.
Sid
10-06-2002 17:53:18
I have burned them into, not set the whole mess afire,it works, but I prefer to use a sharp corn knife it is longer more leverage hands not in manure.
