HP for Mohawk 1100 chisel
JWhite
10-10-2002 16:28:55
How much horsepower is needed to operate a Mohawk chisel plow? It has 6 adjustable points on the rear beam and 5 adjustable points on the front beam.
JMS/MN
10-10-2002 23:16:54
 Re: HP for Mohawk 1100 chisel in reply to JWhite, 10-10-2002 16:28:55
Usually figure at least 10 hp per shank, if you expect to pull it at a speed good enough to do decent damage. Tried out a Mohawk once, it jigged all over the place- bought a Glencoe, runs level at a higher speed. Difference in how they hang the shanks, and the spring placement. 22 years on the Glencoe, almost no repairs.
paul
10-10-2002 19:25:27
I pulled mine with 10 shanks with my Ford 7700 for 1 year, rated at 85 hp - but I felt real sorry for the tractor, & I was not doing a good job with the plowing, more like field cultivating.
Works much better now with the TW20, 135 hp or so. That's what I would want.
How is the hitch on yours? About 75% of the Mohawks I see around here are heavily welded right under the first cross beam.
--->Paul
