Advice on finishing mowers
Mike in Ohio
10-14-2002 07:16:16
I'm in need of a 6' finishing mower. I've been looking at the Sitrex and Rhino. I've only got about three acres to cut but only want to buy once. I can get the Sitrex for $1050.00 (decent price) and the Rhino FM for just under $1700.00, which isn't cheap I know. Any advice with these two mowers would be greatly appreciated!
Jeff (N. Ireland)
05-23-2003 08:25:26
 Re: Advice on finishing mowers in reply to Mike in Ohio, 10-14-2002 07:16:16
Sitrex rear finishing mowers have been imported into Northern Ireland recently. Some are sold under their own name, others marketed by a long-established and respected local brand called Fleming. I have inspected them at a local dealer and can confirm that they are very heavy and solidly made. Dealers have been trying to demonstrate them but the weather has been so bad it's been impossible to say how good a finish they can give. They can cut long grass though.
NavistarRV
10-16-2002 08:30:25
Although it wasn't on your list, I have been using a 60" John Deere finishing mower for the past 5 years. I am very happy with it. It is three point mounted. It has height adjustment from 2 - 6 inches, and leaves a manicured look to the grass. It does not like long grass however. Anything over about 10 inches and it comes out pretty scruffy looking. Then I make a sceond pass the next day. But you can sure cover some ground with a six foot path mowing in third gear behind my S-MTA Farmall.
Duane(Pa)
10-15-2002 13:43:59
I bought a Woods rear discharge six footer and like it. I saw the Rhino about two weeks later and wished i had seen it earlier. That Rhino looks stout. Whatever you buy, grease it with the best grease money can buy. Grease is cheap, spindles aint!
Kajun
10-15-2002 10:34:40
Mike:
Know nothing about those two brands of finishing mowers. Have used and used hard for 10 years a Landpride 90" mower. If 72" is any thing like mine,you can't go wrong with Landpride.
Kajun
Kajun
10-15-2002 10:33:58
Mike:
Kajun
Kajun
10-15-2002 10:33:57
Mike:
Kajun
Kajun
10-15-2002 10:33:50
Mike:
Kajun
Roger in SeMO.
10-14-2002 19:17:43
For the past 10 years I have used an 871 Ford and a 6 foot Woods mower to mow our 10 acres. I think your 600 will have no problem with a 6 footer. I would also vote for the rear discharge in the new Woods model. Good luck. Roger Allgood
John A (TX)
10-14-2002 10:12:21
It's been awhile since I've done much checking on finishing mowers, but Woods used to be considered one of the better brands. HTH
Mike in Ohio
10-14-2002 07:23:49
Forgot to mention that I'm going to use it on a Ford Model 640, 31 hp. tractor. Is the 6' too much for the 640 to handle?
Mike in Ohio
10-14-2002 07:22:00
Jim WI
10-14-2002 10:37:08
 Re: Re: Advice on finishing mowers in reply to Mike in Ohio, 10-14-2002 07:22:00
Don't know anything about the two brands you mention, but your tractor ought to be able to handle a 6-footer. I mow with a 6-foot King Kutter finish mower behind a 2N and only have trouble if the grass is WAY longer than it should be (a foot or so). Even then, the mower starts cutting way too ragged to be acceptable well before the tractor bogs down.
jim
10-14-2002 12:57:14
 Re: Re: Re: Advice on finishing mowers in reply to Jim WI, 10-14-2002 10:37:08
Look for a model with rear instead of side discharge and you'll be able to run 6' easily and maybe even 7'. With rear discharge, the grass is eliminated behind each blade instead of being moved across each blade to the side opening. Safer too as everything is discharged rearwards. These models have just recently become available and you may have to look around to find them.
