Box Scaper
Jeff
10-17-2002 06:52:00
Will my 8N handle a 6 foot Box scraper?
Jim.UT
10-17-2002 11:39:26
 Re: Box Scaper in reply to Jeff, 10-17-2002 06:52:00
I have a 7' box blade and I like it because it's just a shade wider than my rear wheel track. That way I can scrape right up next to a wall if I need to (and I've needed to a couple of times). have a Ford 850 with significantly more hp than your 8N.
Mike
10-17-2002 09:31:44
Really depends on what you're trying to do with it. If you put all the cutting bars down as far as they will go, then I would say no. I have a John Deere 5105 that has a hard time pulling it like that. I also have an 8N and use the box (6') with it some doing light dirt work, spread gravel on my drive way, etc. It dine fine with that so if it's nothing to heavy, you'll be fine with it.
