Denny-Oliver drill settings
Tim(nj)
04-21-1999 07:14:13
Denny, I have the chart for the Oliver drill. If you tell me what you want to plant, and how many bushels per acre, I can give you the the right gear settings. Don't know if you know, but there is a slider gear under the left side of drill that moves up and down on the flat rate disk.
Denny
04-21-1999 15:19:44
 Re: Denny-Oliver drill settings in reply to Tim(nj), 04-21-1999 07:14:13
Tim,Thanks! I am going to try to plant Alfalfa, Timothy, and another grass seed to redo a hay field I plowed down. I'm new at this so hope you can help me. Thanks again, Denny
Paul
04-21-1999 18:37:28
 Re: Re: Denny-Oliver drill settings in reply to Denny, 04-21-1999 15:19:44
Denny,
You'll be using the small grass seeder on
the front of the drill for these
seeds. The calibration for these
seeds is on the dial which moves as you twist the rod on which the
fluted seeders are mounted. I believe
it is calibrated in quarts...
Denny
04-22-1999 14:16:53
 Re: Re: Re: Denny-Oliver drill settings in reply to Paul, 04-21-1999 18:37:28
Thanks for the help!
Denny
