Brush Hog driveline adjustment
Kurt Reitz
10-28-2002 15:00:38
A friend recently gave me a brush hog that he had sitting around for awhile. Upon mounting it I discovered the driveline shaft was too short. The Question: How do drivelines adjust for length? If there are two pieces which slide together, are there usually set pins or set screws?
(I'm guessing the two pieces are rusted together and am wondering just how much force I can apply to seperate them!)
Thanks for any suggestions.
Nick
10-28-2002 15:51:09
 Re: Brush Hog driveline adjustment in reply to Kurt Reitz, 10-28-2002 15:00:38
Kurt,
The line should slide freely, no pins or set screws are present so that the shaft will elongate as needed when lowering the mower. I recently bought at auction a 5-foot mower that was in fine condition except the drive shaft was frozen. After spending many hours I finally had a guy a a metal fab shop hook a 40,000 pound lift to it while the other end was fastened to a large load of steal. The shaft slid open and revealed just a thin layer of rust.
Just a small amount of rust can bind the shaft together. Other means I tried include heat, soaking in diesel, and a bit of pounding. None of these worked, but in some cases they might.
When i got back home I wire brushed the shaft and treated it with navel jelly. It now works fine.
Nick
