Baling corn stalks with nh chain baler
agman
11-03-2002 19:14:31
Will a chain baler work for baling corn stalks. This is my first time to try and bale corn stalks, will chop and rake then bale, how critical is moisture level when baling, this is my first time with stalks so any suggestions appreceiated.
david
11-04-2002 06:47:52
 Re: baling corn stalks with nh chain baler in reply to agman, 11-03-2002 19:14:31
If possible try not to chop the stalks. Rolls need a lot of twine wraps b/c they will want to disintegrate. Moisture content, lower the better.
paul
11-05-2002 07:43:21
 Re: Re: baling corn stalks with nh chain baler in reply to david, 11-04-2002 06:47:52
How do you get anything in the baler without chopping? Do you have any fingers left on the pickup when you're done? Don't understand, _everyone_ chops around here, I wouldn't know what you get? Just curious. If you have a big corn header, folks will follow just the 4 rows behind the combine, get more husks, but still they chop.
--->Paul
david
11-05-2002 08:21:56
 Re: Re: Re: baling corn stalks with nh chain baler in reply to paul, 11-05-2002 07:43:21
We have 0 combines in county, all corn picked with 1 and 2 row pickers. Run over the ground with disc mower, rake and bale. True it is hard on baler. Much prefer grazing stalks to baling but this year beggers can't be choosers on feed.
scooterhead
11-04-2002 05:27:56
I have used mine to bale corn stalks and it will do a good job , they need to be dry , get in there right behind the picker
scooterhead
11-04-2002 05:27:44
