Blade work
hay
11-14-2002 12:56:28
just wondering what do you all like best for dirt work, box blade or grader blade and why? i was out doing some grader blading earlier and it is easier for me because the blade will tilt/angle and can get to more odd corners and shape up ditch lines better. although the box blade has the advantage of pulling a bigger roll of dirt a longer distance and i can smooth out better with it and it has a two way blade for cutting. any thoughts on this?
raytasch
11-14-2002 17:48:47
 Re: blade work in reply to hay, 11-14-2002 12:56:28
hay, I think you said it all except the advantage of the rippers on a box blade. Ya got ta fit the tool to the job.
ray
