Fast Hitch Sickle Bar ID
PeteNy
11-18-2002 15:10:55
Guys, Bought a mower for the Super C this weekend, no tag on it, anyone have any idea what the model # might be, and who might have reprint manuals for it? thanks
Hugh MacKay
11-19-2002 15:30:10
 Re: Fast Hitch Sickle Bar ID in reply to PeteNy, 11-18-2002 15:10:55
There was also a C-28, came either fast hitch or 3 point This one did not require the rod along side to touch control.
REMMo
11-18-2002 18:05:05
I think the bracket might have a rod attached that goes up to the arm on the right side of the touch control. I've got one that may be the same. Don't know the model and havent had it on for several years. Trying to remember. I think the fast hitch just carries the mower at a set level and the bar is raised and lowered with the touch control arm attached to that bracket. Someone will probably come up with a model. REM
REMMo
11-18-2002 18:03:13
Steven M
11-18-2002 16:14:37
We need to know more about it. Wheel in the back?
Pitman type or Balanced head?
Pete Pitcher
11-18-2002 16:17:56
 Re: Re: Fast Hitch Sickle Bar ID in reply to Steven M, 11-18-2002 16:14:37
Steven, No wheel in back, and pitman type. A bracket of some sort that is on the right(bar) side that appears that it hooks somewhere on the tractor. Sorry to be so helpless sounding, I have always been into only the tractors...just starting to get into implements. Thanks
Mark Peters
11-18-2002 16:57:11
 Re: Re: Re: Fast Hitch Sickle Bar ID in reply to Pete Pitcher, 11-18-2002 16:17:56
Pete, It sounds to me like you have a C-24 Fast Hitch mower that was made for the Super C,200. The bracket you mention mounts to an axle clamp (the same type clamp used for mounting cultivators on non-fast hitch C`s and Super C`s) on the right side.This is my best guess. Mark
Mark Peters
11-18-2002 16:54:39
PeteNy
11-18-2002 17:56:58
 Re: Re: Re: Re: Fast Hitch Sickle Bar ID in reply to Mark Peters, 11-18-2002 16:54:39
Mark, Thanks very much, very helpful. Pete
