Forklift Attachment
Murray Davis
11-19-2002 21:52:15
Does anybody have plans for a forklift attachment that you could fit onto an IHC M? I have an M that is not doing much, and I have need for a forklift once a month. I do not want to change the steering or anything like some people do. I just need it to unload pallets once in a while.
paul
11-20-2002 20:20:47
 Re: Forklift Attachment in reply to Murray Davis, 11-19-2002 21:52:15
Lot of different 3-point systems out there. If you adapt that to a bolt-on/clamp-on frame, you would need to give it hydraulic power (some just work on the 3-point action to sissors the lift higher). You'd probably want a front pump for that.
I'm thinking you have an M without live hydraulics, no 3-point or fast hitch. A narrow front is also a negative for stability altho not so much so with the weight in back, which do you have?
If you have more than I'm thinking, let us know. :)
I understand it's not hard for a machine shop to turn an old mast into something useable on a tractor.
--->Paul
