Bush hog blade sharpening
Ted
11-24-2002 03:16:03
What is the correct procedure for sharpening bush hog blades? Is balancing the blades involved, if so, how should it be done?
Thanks
tim
11-24-2002 11:20:55
 Re: bush hog blade sharpening in reply to Ted, 11-24-2002 03:16:03
You can do it on the mower if you have enough room and block up the chopper so it doesn't creep down(just incase). Take a angle grinder and grind the edge back. Don't get them real sharp, you're just wasting time cause they'll just dull faster. Just get a decent slightly rounded edge.
Sid
11-24-2002 06:26:00
I do not know what the correct procedure is what I do is touch them up on the machine. If they are getting beat up bad and need a lot of sharpning I take them off and have a guy that rebuilds the edges for me. He then heats and beats an edge on them. He would then weigh the blades for balance, and either grind or build up a bead. Not sure this was necessary but his desire was to do it as right as possible. I guess I should say I used to take them to a guy He has moved recently.
