What combines used Chrysler short block flatheads ?
Alberta Mike
11-28-2002 05:18:26
Anyone out there know which of the older combines might have used Chrysler flathead 6-cylinder engines that were the "short" or 23" long block? These were also used in a lot of old tractors too.
Hugh MacKay
11-29-2002 19:21:54
 Re: What combines used Chrysler short block flatheads ? in reply to Alberta Mike, 11-28-2002 05:18:26
Mike: How is the prairie guy with salt in his blood? I thought all combines except Deere and IH had Crysler flat heads, but then I am no combine expert.
Alberta Mike
11-29-2002 21:02:31
 Re: Re: What combines used Chrysler short block flatheads ? in reply to Hugh MacKay, 11-29-2002 19:21:54
I never knew that about the Chrysler flatheads and combines. Maybe you're right. What's this about salt in my blood ... are you reading my mail?
Rick
11-29-2002 04:24:54
Are you lookimg for complete engine, parts or what. I was thimking the 525-535 Oliver had that motor will double check. I know where one sitting if that will help
Alberta Mike
11-29-2002 05:02:42
 Re: Re: What combines used Chrysler short block flatheads ? in reply to Rick, 11-29-2002 04:24:54
Actually there is a fellow in Ohio who contacted me looking for a manifold for the engine on his Love tractor (ever hear of those)? I will let him know of your response here and he could contact you through your email link if that's OK.
Steven M
11-28-2002 05:53:55
Massey Harris used Chrysler industrial engines.
The Massey Harris 60 S.P. had a 230.2 cu. in. L head 6 cylinder.
I had a Piere governor. You had to oil it. It did not get oil from the engine.
Other Massey Harris combines also used Chrysler engines.
Dick2
11-28-2002 07:51:27
 Re: Re: What combines used Chrysler short block flatheads ? in reply to Steven M, 11-28-2002 05:53:55
Cockshutt 112SP combines used a Chrysler Industrial engine, but we were told that it had a slightly larger piston and slightly longer stroke than the U.S. version. No muffler, just a long vertical exhaust pipe; I loved the sound of that engine when it was working.
