Ih 4 bottom 16 moldboard plow
max adams
11-29-2002 13:48:29
what i'm wondering is.the plow that i have is semi-mount.what i want to know is what model it is.i think it used to be a 5 bottom? not that it matters.no trip springs,it has the rubber pieces above the mold boards.i know this is not a whole lot of information.the only thing i can see
of the decal is McCORMICK INTERNATIONAL then what
i believe is a 5something.again i would be thank-
ful for any information.thanks in advance...max
Hugh MacKay
11-29-2002 19:12:53
 Re: ih 4 bottom 16 moldboard plow in reply to max adams, 11-29-2002 13:48:29
IH used some model numbers on this one that confuse. In the late 1960s there was model numbers 530, 540, 550 and 560, which were respectively 3, 4, 5 and 6 bottom plows, 14 and 16 inch were available.
Later in the mid 1970s they came out with the model 510 available in 4,5 and 6 bottom 16 inch or 5 and 6 bottom 18 inch only. These were all semi-mounted plows. The confuseing part here is IH had a history of using larger numbers on later models of everything. Rarely did they use a smaller number on a later model of the same basic machine.
Tim(nj)
11-29-2002 17:34:13
The 540 was available as either a 4-bottom or 5-bottom plow according to my manual. I think the 550 was 5 or 6 bottoms, and is built heavier.
TP from Central PA
11-29-2002 15:20:09
Sounds like it is a 550 IH..... .Since it is a 4 bottom now I guess you would have to call it a 540....
