Continental belton digger
mark hathaway
12-01-2002 16:20:37
i have two continental diggers and trying to make one good one.my question is how the shaft that the ring gear is on comes out of the gearbox?my guess would be it drops out the bottom.also i haven't determined how the ring gear comes off this shaft.pressed on to splines,keyway,screwed on ,HOW?
If anyone out there can help with info or pictures i would greatly appricate it.this digger coupled up with 1947m farmall got a hole lotta holes to drill this spring.
Dan Mason
01-16-2006 11:25:45
 Re: continental belton digger in reply to mark hathaway, 12-01-2002 16:20:37
The shaft has a keyway and the gear was installed hot. Heat the ring gear at the keyway and apply steady pressure from the top. I am looking for a good shaft for my digger.
Scott Houtex
12-04-2002 06:52:10
I don't know anything about your digger, but
perhaps the factory can help. Continental Belton
is now AG.-MEIER, INC
1000E 6th st
Belton, Texas 76513
254-939-3731
