Champions park D16 plug
Greensburg, LA
12-02-2002 08:44:53
What is a good replacement for this plug.
lc
12-07-2002 10:13:42
 Re: Champions park D16 plug in reply to Greensburg, LA, 12-02-2002 08:44:53
Anything that crosses over, FROM ANOTHER COMPANY.
Steve from New Holland
12-03-2002 04:29:32
If the tractor or engine is old, (before 1950 or so) You will want to step up to the D-21 spark plug. D-16 is just too cold for the low compression motors. For newer engines with a little more compression, the D-16 is good IF you are working the engine pretty hard. However, even if it is a newer engine, but you are just playing with it, stick to the D-21. Steve
Joe (Wa)
12-02-2002 19:53:51
The new cat# for Champion D16 plugs is 516. Most Napa stores carry them. I get better service with Autolite 316 as a replacement on my old Case tractors. Regards, Joe
ooops-Joe (Wa)
12-02-2002 20:00:09
 Re: Re: Champions park D16 plug in reply to Joe (Wa), 12-02-2002 19:53:51
Make that Autolite 386 as replacement.
