Bush hog and saplings
Pat
12-03-2002 16:25:24
Hello,
I have a small crawler that I am installing a 3pt and pto on to bush hog with-(do not want any cut tires).
My question is: How large of a sapling can I cut with it? The 'hog is not a very heavy duty unit (jd 503), but has shear pins and rotating blades with front safty chains.
I need to cut clumps of about 20 saplings in a 3-4' diameter all saplings smaller than 1-1.5" in dia.
Thanks in advance- I'm a little new to the aspect of mowing brush!
Pat
Must read post for first time bush hoggers
12-05-2002 10:20:00
 Re: bush hog and saplings in reply to Pat, 12-03-2002 16:25:24
This is a link to a post that has been oft repeated on the Ford N-series board.
pat
12-05-2002 10:26:38
 Re: Re: bush hog and saplings in reply to Must read post for first time bush hoggers, 12-05-2002 10:20:00
pretty good story!!!! I can relate to alot of that--especially the briars!!
Pat
Punchie
12-04-2002 16:23:57
HI Pat
First be safe, you can get into a real mess brush hogging TAKE YOUR TIME!!
I cut with a WD Allis Chalmers ( 35 HP) , 5 foot woods with longer blades. Front tires need fixed from time to time , not too offen do the back go down. Watch for junk, that is the biggest thing that is hard on the tires.
I would not run the brush hog too low to the ground. Hit stumps etc. and ground, hard one the blades etc.
Use grade 5 sheer bolts or softer , maybe run at 3/4 speed ( throtlle ) (sp) . Better to stall the tractor than to brake your hog.
Watch your self on hill sides.
I cut up too 3'' ( base ball bat size) trees thats about as big as I can go, thats for locust and oaks single trees. Maybe a little bigger for sassafas( sp) and softer wood. Broom handle size should be no big deal, thats what they should be made for; Brush Hog.
Greese and check the equipment make sure guards are in place , wear glasses . Maybe back over the bigger brush. Run trees over with the back tire or track first .
Have a Good One !!
Punchie
pat
12-05-2002 06:19:22
 Re: Re: bush hog and saplings in reply to Punchie, 12-04-2002 16:23:57
Thanks for the advice, 3" is pretty big stuff!! I don't have anything that big to deal with-(thank goodness)!
Later, Pat
Pat
12-04-2002 08:53:54
Thanks for all of the help guys!!!
I feel much better knowing it has been done before and that it won't hurt anything. I like to get work done, but do not like destoying the "wrong tool" while doing it!
The little crawler also has brush screens to keep the most flying pieces and briars at bay, as well as keeping the paint ON my rubber tired tractors!
I can't wait to get started- souds like a slow project, but hey- what could be better than spending time on a tractor!!!
Thanks again to all, Pat
Tom a
12-04-2002 06:35:41
Pat:
I reconditioned about 5-8 acres of very overgrown pasture with an old 8N tractor (about 27 hp) and a fairly light 5' no-name brush hog.
Chopped up many saplings the size you said without any problems...didn't even break a shear pin for a long while. Over the course of a year or so, I got more and more overconfident. Not sure at what point they became 'too big,' but it was definitely just fine to 1.5". As everyone said, go slow to keep the hog's blade speed up, and take partial passes if need be.
Tom
Ron
12-04-2002 06:28:41
Have the Blades Sharp...!!!!
Go SLOW, and I would cut them down low....The lower the better, so you don't leave stumps sticking up... BUT---you don't want to go over too much stuff at once...take a partial swipe, if you have to.....and wear a heavy coat and hat..!! Those chains may not stop all the pieces....!!! SHARP blades are the key....will cut much better, with less power....and wear and tear...!! I like to use Moly grease, or Spray on Graphite on the blade pivots... A PTO slip-clutch--set to just hold, but able to slip enough to take the shock out will protect the driveline... Cutting saplings is hard on these mowers, but they will do it...!! Live power take-off is a real help, here..!!
jimbo
12-04-2002 03:07:28
have some extra shear pins handy. Would be easier if your mower had a slip clutch. Good luck.
jimbo
12-04-2002 03:06:08
Mike D.
12-03-2002 19:27:43
We mowed several grown over pastures the past two summers. Trees where bigger than you describe. Used a 50 hp. tractor. Never poked a hole in a tire. Never had a moments trouble with the bushog.
We have a medium duty 6' mower. Mowed over a lot of gum trees. That was slow going, but it worked out just fine. Do you have a farm tractor?
pat
12-04-2002 08:44:00
 Re: Re: bush hog and saplings in reply to Mike D., 12-03-2002 19:27:43
Mike, I do have a reg tractor to, but just afraid of holes in tires. Glad to hear you had no holes in yours!! Makes me feel a little better!!
Mike D.
12-04-2002 11:08:04
 Re: Re: Re: bush hog and saplings in reply to pat, 12-04-2002 08:44:00
Yep, now if you were mowin for the second time in a season and you had a staub leftover from mowing early in the spring you might poke a hole in your truck tire. I had a friend do that. But I'd have to say I've never heard of anybody hereabouts that has pushed up a staub through a tractor tire.
Pat
12-04-2002 11:49:42
 Re: Re: Re: Re: bush hog and saplings in reply to Mike D., 12-04-2002 11:08:04
Mike,
sounds like I'll just mow it the first few times with the crawler-it is kinda fun to play with anyway.
Thanks, Pat
Mike
12-04-2002 13:03:21
 Re: Re: Re: Re: Re: bush hog and saplings in reply to Pat, 12-04-2002 11:49:42
a.o.k. Pat, How much have you got to mow? We got an old Case 450 loader, I would not have enjoyed mowing all that we had to mow ridin on that thing. Don't have your track chains too tight, no sense wearin out your crawler's ground work for a mowin job...
Let all of us know how you got along with the job.
Best of luck on it. Mike
pat
12-05-2002 06:16:30
 Re: Re: Re: Re: Re: Re: bush hog and saplings in reply to Mike, 12-04-2002 13:03:21
Mike,
It may be about 4-5 acres tops-not too much. The ground is pretty rough, it will be a rough ride even on a rubber tire tractor!!
I'll let you all know how it goes!!
thanks, Pat
Pat
12-04-2002 11:49:11
Mike,
Thanks, Pat
