Continental motor off mc cormic Deering 50T bayler
Michael Carr
12-08-2002 11:27:30
My father is looking for any info or links to info for a continental motor model#IY69 serial#91476 came off mccormic deering 50T bayler thanks in advance all info apprecated
Harold H
12-08-2002 13:46:29
 Re: continental motor off mc cormic Deering 50T bayler in reply to Michael Carr, 12-08-2002 11:27:30
All of my specs show the IHC Cub engine which was rated 16 hp on the 50T although I know some early were equipped with the 13.5 hp Y-69 Continental. I think the I on your model number meant it was built for International Harvester Company. Here are some specs on the Y-69 Continental: 68.7 cu in, 2 1/2" x 3 1/2" bore & stroke, L head, 13.5 hp @ 1500 rpm, 6.7 to 1 compression ratio, 265 lbs net weight, 25 15/16" overall length, 14 3/16" overall width, 25 1/8" overall height, 45/64" diameter wrist pins, 1 1/2" diameter connecting rod bearings, 1 3/4" diameter crankshaft bearings, 3 crankshaft bearings, 4 7/8" total length crankshaft bearings, pressure lube system, either Novi or own governor, 1 1/16" intake valves, 7/8" exhaust valves, 1" carburetor size, 3 rings per piston (2 compression and 1 oil), 3/32" width compression ring groves, 1/4" width oil ring grove, 18mm spark plugs, thermo syphon cooling. Hope this information helps.
Harold H
bob corveleyn
10-19-2003 09:43:16
 Re: Re: continental motor off mc cormic Deering 5 in reply to Harold H, 12-08-2002 13:46:29
I saw your message. I have a I Y 69 Continental Engine on a early IH Hay baler. I am trying to set the timing. The firing order is 1342. I need to know if #1 cylinder is toward the Fly or the Front. Also I have found the TDC Mark on the Flywheel. I don't see a pointer through the inspection hole.
