Bush Hog Offset Disk
Tom
12-10-2002 06:49:14
Have found a Bush Hog offset disk plow; says Model No 145, Serial No 11-00-477. About 6 1/2 foot cut. 9 disks in each gang. 3 bearings on each gang. Disks about 22 inches. It is a pull type with cylinder to raise it. Anyone have any experience with this offset? What quality? When made? Any info appreciated.
Shep
12-10-2002 13:17:24
 Re: Bush Hog Offset Disk in reply to Tom, 12-10-2002 06:49:14
Offset discs have their place, but they are not the best in all situations. We pull a 9 foot brillian offset disc with 24 inch blades and it takes 100hp tractor to pull it through our clay soil if you let it dig. We also have a 19ft Athens double offset disc with 26 inch blades and I can pull it with the same tractor and cover much more ground at a time, but it doesnt dig like the offset does. I find the offset disc useful to get crop residue in the ground and break up the top of the dirt, but it will compact a field pretty fast if it is a little wet or if you use it too much in one field it will create a hard pan in the soil fast. This type of disc also tends to berm up the soil and not leave a very level surface, even when it is working good. I typically run a deep ripper or a field cultivator and only use the offset disc if it looks like the field cultivatior will not take care of all the residue on the top before planting. I am not a big fan of discs as a primary tillage tool, like the offset discs are made for.
Just my 2 cents for today
Tom
12-11-2002 04:27:46
 Re: Re: Bush Hog Offset Disk in reply to Shep, 12-10-2002 13:17:24
Shep,
Thanks for the input. I learned something. Looked at your website and enjoyed it. Keep up all the good work.
Pete in Ks
12-10-2002 11:36:31
I have a 10' bushhog offset. Very heavy duty disc. I pull it with a 70 horse Oliver. Can't say when made. Like it OK eccept in hard pack. Doesn't want to go in on one side, but a couple of passes in different directions and it cuts. Probly needs the disc's rolled but I don't use it that much.
Tom
12-11-2002 04:31:26
 Re: Re: Bush Hog Offset Disk in reply to Pete in Ks, 12-10-2002 11:36:31
Pete,
Thanks for your help. I learned something. What do you mean by getting the disks "rolled"? Is that resharpening them, and who does that? Is your offset a Model 145 or 146 by chance? Bush Hog told me they made these two models.
BILL EOFF
12-10-2002 07:21:53
TOM-I HAVE A 6 1\2 TAYLOR WAY OFFSET WITH 26 " DISK I PULL IT WITH A 70 HP J\D IT IS ALL IT CAN HANDLE IN HEAVY SOIL-WORKS GOOD WHERE YOU DON'T HAVE COVER OR YOU ARE BREAKING EVERY YEAR.
I BURN AND THEN DISK ONCE AND GO OVER AGAIN WITH THE WHEEL UP SAVES FROM HOOKING TO ANOTHER DISK
Tom
12-11-2002 04:37:20
 Re: Re: Bush Hog Offset Disk in reply to BILL EOFF, 12-10-2002 07:21:53
Thanks Bill. From your post, it sounds like this disk may be just what I need. It is 6 1/2 also and my tractor is 66 PTO HP. So it would be a full load. If I can buy it worth the money, I will use for oat fields in the fall.
What do you mean about the second pass "with the wheel up"?
