Bush Hog for 8n
R.L.Meiller
04-26-1999 21:16:45
I would like to mow paths around our land and will run into bogs and 1 to 2 inch saplings. What size mower would you recommend? Also, will this easily work with the 8n or are there other attachments that I will need to purchase to make it compatable?
Brian
04-28-1999 18:59:21
 Re: Bush Hog for 8n in reply to R.L.Meiller, 04-26-1999 21:16:45
Be sure and use an over-running clutch or else you be into the fences, trees, creeks, etc. Should be around $75 but well worth it on any tractor without live power.
Jeb Lloyd
04-28-1999 12:47:49
I have a 1947 2N and it can easily pull a 5-ft bush hog. The 8N has more power than a 9 or 2N, so I know that this will work. You shouldn't need any attachments to hook it up; just use a standard 3-pt hitch model and a basic telescoping universal driveshaft, and you'll be just fine. Let me know if I can answer any other questions. I don't know all there is, but I know some things.
jrmo
04-27-1999 11:17:31
go to the n board and ask. those guys will be able to tell you any thing you want to know about it. Look under "additional forums" at the top of this page.
