Battery Tray
Free Bird
12-16-2002 13:36:47
Pulled the battery out of my 1965 Ford 3000 noticed a bit of rust and corrosion. I want to remove rust/corrosion and recoat the tray with a material/paint to prevent this from happening again.. All help appreciated
norm
12-18-2002 09:44:59
 Re: Battery Tray in reply to Free Bird, 12-16-2002 13:36:47
The only way you can really prevent battery corrosion is to get a sealed battery such as a "Delco" or "Optima".
mj
12-17-2002 07:26:36
Get it all cleaned up and painted then find a plastic battery tray like the early 70s' Datsuns had and put it on your rack. Plastic won't corrode.
mj
hay
12-16-2002 13:45:32
you might try rust removal with naval jelly. recoat it with a good epoxy paint.
