Cub Farmall coil hookup
okla/kans Bill
12-21-2002 09:13:04
on a 48 Cub ive got the coil hooked negetive to the mag. Is that right? Im getting fire toand on the + side, but no fire on ther -side. and thus no fire to the plugs
Bigdog
12-22-2002 04:35:51
 Re: Cub Farmall coil hookup in reply to okla/kans Bill, 12-21-2002 09:13:04
The coil grounds through the points, so whatever polarity your electrical system is (should be positive ground if original), is what terminal that gets connected to the points. If you've got an external coil on a mag, that's not original. In either case, there will be voltage at that terminal only when the points are open.
Bigdog
12-22-2002 04:34:29
