# 5 JD mower
Dave in Ohio
12-22-2002 14:41:01
This is the URl for the picture that should be on the message below. www.ImageEvent.com/dalinfamily/oldironalbum Just cut and paste into your address block.
Bigdog
12-23-2002 04:35:01
 Re: # 5 JD mower in reply to Dave in Ohio, 12-22-2002 14:41:01
Dave, have you looked at both the sickle and the bar to see if either is bent or warped? It looks like the knife makes normal contact farther down the bar. Does it have contact at the end of the bar as you insert the sickle? How about the hold downs. Can you physically push the knife into place with some downward pressure?
