Ih little genius plow?
sjh
12-23-2002 12:06:34
I need to replace my rotten tires on my plow. Are there used vehicle tires I can use, or do I have to buy new tires. Thanks Scott
Hugh MacKay
12-26-2002 03:52:41
 Re: Ih little genius plow? in reply to sjh, 12-23-2002 12:06:34
The trailing tire will probably need to be new, as it has the angle on its tread. Any tire the right size will work in furrow. The land side wheel needs quite good traction if plow is a clutch lift. New mud and snow tires work well but I suspect they are more money than the proper implement tire.
Hugh MacKay
12-26-2002 03:52:21
