Planting brome with Van Brunt drill
agman
12-31-2002 19:47:55
This summer I tried planting brome with my "newer" JD Van Brunt drill (galv. box, rubber end wheels). The brome was mixed with oats in the main box and seemed to keep puffing up above the seed metering wheels and not continue to flow into the feeder wheels, what is the deal, the owners manual even says I can plant brome in the small seeder box, which is much smaller than the main box I am trying to feed out of, this is just standard smooth brome like you plant in Illinois, none of that native grass stuff. Any ideas? Thanks.
old Timer
01-01-2003 14:53:38
 Re: planting brome with Van Brunt drill in reply to agman, 12-31-2002 19:47:55
mix lbs. per acre of brome you want with 100 lbs. or what lbs. fertlizer you want set fertlizer box on the lbs. per acre.
Tom
01-01-2003 16:13:51
 Re: Re: planting brome with Van Brunt drill in reply to old Timer, 01-01-2003 14:53:38
Not in my drill - NO FERTILIZER. Use the samll seed box for the broome and large seed box for the oats. my 2CTS
old Timer
01-01-2003 14:52:40
Rick
01-01-2003 05:33:40
You just learned what experience teaches you. The book always make it sound easy. Your problem is common. How much oats did you mix with. It works better have a carrier because of lightness of seed. Sometimes on lighter seed in drill works better go larger opening and change gear ratio to get you rate.For real fun try planting big bluestem!! Its like cotton thru garden hose!!!
JD
12-31-2002 20:05:13
When i plant Brome i also plant it with Oats. Brome is the @#$% thing to plant.
