How to stop multi post.
Kelly C
01-04-2003 12:45:59
I have found that when you click on post your message. The system will hang about 75% of the time. I then open a new window and have found that every time my post is on the site.
You only need to click on post your message once. It still gets there.
10
01-05-2003 19:08:07
 Re: how to stop multi post. in reply to Kelly C, 01-04-2003 12:45:59
i hit the post it then walked away came back a few min later nothing had changed so i decided to skip it but laternoticed my messaged posted four times in five minute time span. only have had trouble on impl board
10
01-05-2003 19:08:00
Old Iron
01-04-2003 13:11:56
Kelly C.
I have lost count on the number of times this has been talked about here. Here is what I do----
When it hangs up, hit the stop button, hit your back button untill you get back to the main board for the topic you are posting to, then it your "refresh" or "reload" button. (Depending on what browser you are using.) Your post will be there.
My 2 bits worth,
Old Iron
tlak
01-04-2003 16:01:04
 Re: Re: how to stop multi post. in reply to Old Iron, 01-04-2003 13:11:56
I noticed just by backing through your post it reposts.
tlak-also
01-04-2003 16:05:16
 Re: Re: Re: how to stop multi post. in reply to tlak, 01-04-2003 16:01:04
If you hit the post button more than once it will multiple post. If your not sure it posted copy your post and close that window and check in a new if it posted.
