I was wondering?
Big red 460 die
01-06-2003 17:55:54
I was just curious what size tractors or you guys using to pull chizel plows? I pull a 9 shank chizel plow with my MF 396 with 4wd and it handles it great. I was just currious what you guys were pullin them with? Thanx.
rem
01-08-2003 16:38:07
 Re: I was wondering? in reply to Big red 460 diesel, 01-06-2003 17:55:54
I pull a seven shank with a Cockshutt 570 Super with a tired 70+ HP 339 Hercules. No problems.
Lary
01-07-2003 18:11:14
We pull a 15 shank with a 4840 and it doesn't feel it ,180 hp
Big red 460 diesel
01-07-2003 18:06:50
We have are MF 396 turning out about 115 horses it pulls it great but lacks a little weight. but after we put 1000 pounds in the front it rips through are blue clay better than are Intermational 1086! Thanx for the info.
Lary
01-07-2003 18:06:11
Lary
01-07-2003 18:02:38
Brian in MO
01-07-2003 16:17:58
I pulled 9 shanks with a 560D turned up to about 85 horse. Had the power just not enough weight so I got a 1256 no problem now except I need a bigger chisel plow. isnt that how it is suposed to work? Brian
Kraig WY
01-07-2003 09:13:06
Somebody told me years ago that you need 10 hp per tooth on a chisel plow. I guess it must be true. I have a five tooth plow that I can pull with my Ford 850, but not with my Farmall B. Want to really have fun I weight it down and pull it with a 4020. I can really plow some ground with that set up.
John A.
01-07-2003 04:59:48
Big Red 460, 13 shanks with a 966 @ 8-10 in.
deep on Central Texas clay and Lampasas River
sand, 110+ hp on this 966.
Hope this helps.
Good luck
John A.
Green Envy
01-06-2003 21:21:37
I pulled a 14ft 14 shank with a JD 820. Also pulled a 24ft 24 shank with the 5010. We use chiesel plows for summerfallowing out here in wheat country.
Green Envy
01-06-2003 21:21:06
Big red 460 diesel
01-06-2003 17:58:19
Man i think this web site is a little screwd up i only wantewd one forum lol. o well sry for the mistake.
paul
01-06-2003 20:35:25
 Re: Re: I was wondering? in reply to Big red 460 diesel, 01-06-2003 17:58:19
A _little_ screwed up??? ;)
Anyhow, I've pulled a 10' 10 point (2" straight) chisel plow with a 85 hp tractor, but didn't think it did a good job. Much happier with a 140 hp tractor on a 10 point, 12' chisel plow now. :)
--->Paul
