High Density Polyethylene (HDPE)
ID-Junker
01-09-2003 06:18:32
Any Input on useing this to make replacement bearings for old wood bearings on MF disk???
thank you
ID-Junker
K24D@excite.com
jim
01-09-2003 16:18:07
 Re: High Density Polyethylene (HDPE) in reply to ID-Junker, 01-09-2003 06:18:32
Wouldn't it be much easier to get some hard maple and make some new wooden bearings ? Remember , those original bearing lasted years with proper greasing. By the way , the straw-walker bearings in my JD3300 combine are wood as well.
ID-Junker
01-09-2003 18:53:09
 Re: Re: High Density Polyethylene (HDPE) in reply to jim, 01-09-2003 16:18:07
Cant Find A good Source of hard maple. Needs to be 3.75 X 3.75 to turn
Scott
01-09-2003 14:28:07
I'd be a little leary of the HDPE for bearings. I work with this stuff on occation, and know that it tends to warp easilly, has a rather low melting temp, and is rather soft. I believe the newer P3 series is a harder material, but not sure about the other things. I'd have to say it would most likely not work well, especially for a disk....lots of rotating on a heavy unit, and you would have holes opened up (warp and disfigurement), and material melting.
Jhill
01-09-2003 12:20:41
A better choice would be Ultra High Molecular Weight Urethane really tough material
ID-Junker
01-09-2003 19:07:13
 Re: Re: High Density Polyethylene (HDPE) in reply to Jhill, 01-09-2003 12:20:41
Thank You do you have any more on Ultra High Molecular Weight Urethane It needs to be 3.75 round.
TimV
01-10-2003 15:46:30
 Re: Re: Re: High Density Polyethylene (HDPE) in reply to ID-Junker, 01-09-2003 19:07:13
You could also try McMaster-Carr for UHMW. I believe they stock it in round sections
TimV
01-10-2003 15:45:15
Jhill
01-10-2003 08:19:32
I comes in stock sizes and is available from plastic houses like Cadillic plastic. I have seen it used to make rollers for cement mixers.
Hard maple would work really well. Try the internet for a source.
ID-Junker
01-09-2003 19:03:24
ID-Junker
01-09-2003 19:02:26
