David Bradley Equipment Colors
Gary Christian
01-12-2003 20:18:22
Have a David Bradley side delivery rake and grain wagon, What were the original colors ?
steve thatcher
11-18-2003 19:44:54
 Re: David Bradley Equipment Colors in reply to Gary Christian, 01-12-2003 20:18:22
I AM REBUILDING A DB MANURE SPREADER I WAS TOLD THAT THE CLOSE THING TO THE RED WAS IH RED AND THE YELLOW/GREEN WAS EQUELPARTS JD GREENAND JD YELLOW. THIS SPREADER IS IN GOOD SHAPE NEED WOOD REPLACE AND PAINTED. I NEED TO KNOW IF ANY BODY KNOWS OR HAS DARWING OF WHERE AND HOW THE SEAT AND FOOT REST ARE. THIS IS BELIVED TO BE A HORSE SPREADER.THINKS FOR ANY HELP
Dick2
01-13-2003 18:40:00
Our DB rake was on off-red, not as bright as IH red. Wheels were lighter green than JD. We put up a lot of hay and used that rake a lot - but stopped long enough to grease the shaft bushings every hour, that's probably why it lasted so long. We also had a DB manure spreader with wooden box. My brother may still have one or both at the farm, although he doesn't use them anymore. My late uncle worked for Sears Farm Stores in IL and ID.
Kenneth Strawn
01-13-2003 12:37:05
Hello, I have a David Bradley hay rake that was given to me by a great uncle. The faded painted appears to be the same red that Fudd was referencing too. Hope this helps, Kenneth
Fudd@work
01-12-2003 20:39:42
We had a new flare box and it was sorta bright red. Our David Bradley plow was red and I think the wheels was light green, sorta pea grean. This was almost 50 years ago so the memory is sorta foggy.
