A-c hay rake needs help
Farmman
01-13-2003 05:34:44
Bought a hay rake in a package deal. The owner says it's an a-c. Did they make a rake? The whole thing needs new teeth. Where's a good place to find them or is there a more common rake the teeth will interchange with. Can't find a listing for a-c rake teeth in any of my supply books.
Catskill Pete
01-13-2003 10:49:43
 Re: a-c hay rake needs help in reply to Farmman, 01-13-2003 05:34:44
AC rake is probably a model 77 [may bee the only model AC ever built? not sure?] I used one for 15 years, good rake. Parts no longer listed from AGCO , but will use the universal rubber teeth and the roller bearings in the bars use the same bearings as NH rakes
Tim(nj)
01-13-2003 10:45:54
Is it the original PTO tedder/rake or later #7, with a swivel wheel on the front end and double-prong teeth? www.sloanex.com has them, it's where I got mine from. If it's a later roller-bar type A-C rake, the universal rubber teeth should work, and I think Sloan has the single teeth for them, too.
JIM Ct
01-13-2003 10:38:18
Just a Thought but the univeral rubber tine might fit.See how thick the bar is or talk to the parts counter at your local dealer AC now part og AGCO and JD says they'll get parts for other equipment.Something should fit might need longer bolts.
Ron
01-13-2003 09:56:47
The AC hay rake was a "Dandy" piece of equipment....did a real nice job....
I don't know where to find teeth, but they were a real good rake... Only odd part about them was learning to Back one in the shed.!!! They were a little "tricky"!!
