Arena base construction
JW
01-14-2003 02:29:30
Have just had arena site leveled and ditched for drainage. Have recommendation (from very experienced and skilled road builder) to put down base of 6" gravel, then 2" of sand mixture for surface.
Thinking about spreading gravel (with tractor blade) and rolling base myself. Where can I find out about how much water to add before rolling. Should all gravel be spread, then watered, then rolled OR do in 2" layers OR what? Any tips for watering and rolling?
Plan to use mixture of sand and rubber for surface. Spread with Bob Cat and spreader bar, thoughts??
Any experience with a project of this sort? I welcome all input, particularly from those experienced with arena or road building.
Thanks
Keith NNY
01-18-2003 22:17:57
 Re: arena base construction in reply to JW, 01-14-2003 02:29:30
I would lay your base in incrimments 4-6" water if you have it. Maybe your base will be a little damp any way compact with a vibrating roller or plate tamper use a transit if level is important.
Good luck
marlowe
01-14-2003 19:48:39
i am in the sand and gravel buss. i do this all the time. for the base use fill with NO stone.stone will work to the top after time. for the top use a clean clay sand mix at about 50-50 plane sand will dry out and be like sugar and very dusty need the clay to bond and hold a little moistur
JW
01-14-2003 23:02:01
 Re: Re: arena base construction in reply to marlowe , 01-14-2003 19:48:39
Marlowe,
I'm a bit confused here. You say NO stone in the base. Does that mean NO gravel? If it does rule out gravel, what do you recommend as the base material? Should all of the base material be spread, then watered and compacted? OR Spread a layer, water and compact, then do the same with the following layers?? What are the guidelines for adding water? Thanks for your input!
JW
PatM
01-14-2003 15:08:41
A gravel base may be a good idea for drainage. But I think you'll want more than 2" of surface. A sand and clay mixture will work up nice and be easy to level. Also give better footing for horses. Probably a minimum of 6 inches would be better (my opinion). Here's a link to a Penn state pamphlet about arena surfaces. Horse Facilities 6: Riding Arena Footing Materials
I spent a number of years managing hunter-jumper barns, and found that plain sand is just too soft, doesn't "hold" the horse's foot an give good traction.
Is this for jumping, or dressage or Western equitation, or both? If you're gonna be jumping you definitely need more than 2" over the gravel, for cushioning, and to keep from getting holes right to the gravel.
JW
01-14-2003 16:54:54
 Re: Re: arena base construction in reply to PatM, 01-14-2003 15:08:41
Thanks for the feedback. Probably will go with a thicker surface. Arena to be used for hack and dressage. Surface will be sand/rubber mixture.
Looking for tips on how to construct base - spreading, watering, and compacting gravel base.
Thanks again!
kraig WY
01-14-2003 08:29:48
I'm assuming you're talking about a horse arena. After you get it built horses are gonna pack it pretty good, and will bring in weed seeds with their poop. You're gonna have to disk it every so often. Don't make the same mistake I did. When you make the chute area (where you back horse up etc. put in a gate so you can drive thru with the tractor/disk/rake. Saves from having to get in there with a roto tiller and doing it by hand.
JW
01-14-2003 14:26:45
 Re: Re: arena base construction in reply to kraig WY, 01-14-2003 08:29:48
This is an equistrian arena, no chutes. My main interest is in how to prepare the base (ie -water, rolling etc). I view the arena as a wide short road with a gravel base. I'm probably looking for 'gravel road building' info as much as anything. Any thoughts much appreciated.
Simple Solution
01-14-2003 10:41:32
Rebuild chute/gate only this time make it bigger.
