Dearborn disc harrow Info.
Farmman
01-16-2003 08:34:24
Have an old Dearborn disc that need some work. Anyone know where I can get Info. on this. Anything would be a help. Thanks
Jim
01-16-2003 19:13:22
 Re: Dearborn disc harrow Info. in reply to Farmman, 01-16-2003 08:34:24
I would check with a farm supply place like Tractor Supply (they used to be Central Tractor or Quality Farm and Family) If you can find a local place that's a Temco (I think that's right) dealer you're all set, because they deal in aftermarket parts for implements and tractors. Good Luck.
Ultradog MN
01-16-2003 15:04:16
Those old Dearborn discs are getting to be valuable. So if you can, keep it working since it will always fetch a pretty good price if you do.
What exactly are you looking for? Bearings I'll bet. Wood or Cast Iron? Try doing a search on the archives here for Disc Bearings. I found a lot of info there about a year ago.
There is a real decent fellow over on the Ford N Board named Ed Gooding from VA. He has just about every manual for every Dearborn implement ever made. He has them all scanned into pictures that he can post or email to you.
I would ask my questions about a Dearborn disc over there too.
Good luck
Phil (VA)
01-16-2003 10:19:40
Another potential source of info and manuals is the "N-Newsletter" at this link:
http://www.ytmag.com/fordnclub/clubs.htm
Scott
01-16-2003 08:45:33
Dearborn farm equipment was sold by Ford tractor dealers from 1948-mid 1950's with some exceptions, Ford is now New Holland, check your yellow pages for a dealer close to you, if they were in business long enough they should have a manual to copy for you, you will need the model off of the plate because they made different styles.
