3 Pt Reversible Scoop
JW
01-18-2003 15:41:58
I'm looking in the local area (Southeast Queensland, Australia) for a 3 pt reversible scoop. No one around here has heard of a "reversible" scoop. There are plenty of scoops around, but can't find a "reversible".
Can any one refer me to a web site that shows a "reversible" scoop or maybe plans for building such a scoop?
Thanks!!
northerntool
01-19-2003 19:45:36
 Re: 3 Pt Reversible Scoop in reply to JW, 01-18-2003 15:41:58
Try northerntool.com they have em cheap. Shipping will blow.
Gary in TX
01-19-2003 13:52:34
www.cadplans.com has a plan for one if you would want to build one yourself. Shouldn't really be that bad to build. Might be the best route to go considering there is none around you there.
TW
01-19-2003 14:08:17
 Re: Re: 3 Pt Reversible Scoop in reply to Gary in TX, 01-19-2003 13:52:34
Gary,
Thanks for the tip. I'll take a look.
TJ
Burrhead
01-18-2003 15:59:09
JW
01-18-2003 21:54:16
 Re: Re: 3 Pt Reversible Scoop in reply to Burrhead, 01-18-2003 15:59:09
Burr,
Thanks for the link. That is exactly what I'm looking for. If I can't find one, might have to weld one up. What size angle do you reckon is used for the scoop frame, and guage metal for the scoop?
Any construction tips or comments??
TJ
Burrhead
01-19-2003 13:02:22
 Re: Re: Re: 3 Pt Reversible Scoop in reply to JW, 01-18-2003 21:54:16
I'll have to check the gage of the bucket but the angle iron is 3" X 3" X 1/4".
My bucket is 30"L X 30"W and 12" deep.
If ye mount the swivel pin in the dead center of the sides it will flip open with a minimum amount of pressure on yer trip rope.
If ye want to ye can email me and I'll send some pix of a frame and measurements.
Burrhead
01-19-2003 13:08:05
 Re: Re: Re: Re: 3 Pt Reversible Scoop in reply to Burrhead, 01-19-2003 13:02:22
third party image
JW here's a bigger pic of the deal.
JW
01-19-2003 15:12:08
 Re: Re: Re: Re: Re: 3 Pt Reversible Scoop in reply to Burrhead, 01-19-2003 13:08:05
Burr,
thanks for the pic. As they say "one picture is worth....".
Couple of questions:
Is the scoop front lip same guage as the rest of the scoop?
From the picture seems the sides of the scoop get more narrow near the bottm of the sccop. Was this accomplished by bending the sides or welding two pieces of material at an angle??
Thanks again for the great picture.
Regards,
JW
Burrhead
01-19-2003 18:52:17
 Re: Re: Re: Re: Re: Re: 3 Pt Reversible Scoop in reply to JW, 01-19-2003 15:12:08
The bucket is bent from the factory, but as soon as it rust away then everybody welds joints and puts the bend in there when making a new bucket.
The front of the bucket has 1/4" flat iron welded the full length of the lip.
They weld a heavy steel washer on the pivot holes for reinforcement.
JW
01-20-2003 00:35:35
 Re: Re: Re: Re: Re: Re: Re: 3 Pt Reversible Scoop in reply to Burrhead, 01-19-2003 18:52:17
Copy and Thanks.
JW
Burrhead
01-20-2003 16:10:11
 Re: Re: Re: Re: Re: Re: Re: Re: 3 Pt Reversible Scoop in reply to JW, 01-20-2003 00:35:35
JW the skin for the bucket is 18" carbon steel
Correction
01-21-2003 17:18:06
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 3 Pt Reversible Scoop in reply to Burrhead, 01-20-2003 16:10:11
the bucket skin is not 18", it is 1/8". I missed the slash 1st time thru
