Dearborn Front Loader
leon bee
01-30-2003 09:08:43
Hello! I just found this forum and haven't yet reviewed all the old posts. Just took possession of my father in law's 8N with original front end bucket. It bleeds down way too fast, what should I look at: pump or the cylinders. Are parts available? Thanks so much!
Gary
02-02-2003 12:10:54
 Re: Dearborn Front Loader in reply to leon bee, 01-30-2003 09:08:43
I've got one of these out back. If you don't get it figured out from what you've got, email me at dorisholtman@aol.com ad I'll look it over closer and holler back at you.
Leroy
02-02-2003 08:37:06
Unless it is the industral model with front mount pump and down pressure on the loader then it would have to be in the tractor because if it would be the seals in the cylinders then it would be pooring the oil out on the ground and that would be obvious, the oil in a single acting: one way; cylinder cannout go past the seals back into the system, it would gout side the cylinder. It could be the rings on the piston for the three point hitch that are leaking. Do you have the three point arms tied down?
Taylor Lambert
01-30-2003 11:00:21
It more likely a leak in the cylinders, do the lift cylinders leak hydraulic oil out from aroun the wiper seal on the ram. If it is you can fix it for around 10 dollars a cylinder. if there not externally leakin you may the pistons with the chevron packing on the pistons. Or its your valve leaking Best regauards Taylor Lambert
Taylor Lambert
01-30-2003 11:00:14
