Ferguson ABO-20 Disc Harrow
Steve Putman
01-30-2003 14:56:08
I'm trying to get an old disc harrow operational and to connect it to my Ferguson TO-20. The harrow is an early pull type from about 1940-42, which was superceeded by a partial lift and then a full lift type a few years later. This one, in addition to the swinging drawbar connection uses a neat trick. The lift arms are disconnected from the lower lift arms and connected to a special boomerang shaped piece. This piece is connected to a bracket which mounts under the tractor seat, and to the harrow by means of a long rod and u-shaped connector. When the lift arms are raised they lift this boomerang which in turn pulls back the rod connected to the harrow, which in turn straightens the discs so that the implement rolls along without churning up the ground until you get where you're going. You then lower the lift arms and thus angle the discs which allow the implement to do its work.
The problem is that I have none of these connection pieces nor have I ever seen anything but pictures of them. Does anybody have some of this stuff to either sell or at least measure so I can try to reproduce them?
Thanks.
Leroy
02-02-2003 08:01:10
 Re: Ferguson ABO-20 Disc Harrow in reply to Steve Putman, 01-30-2003 14:56:08
T have in my hand the parts list for a model A-BO-21 Tandem disc harrow, Form 3183-A, book dated june 1952 and supersedes catalog dated Febuary 1945 form 0-3183, under instructions it says, The model change from the A-BO-20 to the A-BO-21 took efect at Serial Number 22700. At this time a new hitch was incorperated. To convert an A-BO-20 Tandem Disc harrow with the old style hitch to an A-BO-21 Tandem Disc Harrow with the new style hitch, order details listed under A-BO-90 on page 5. I do have some of those parts but not all but with the pictures in the parts book they could be made. also have a parts book for the Dearborn version that is the same disk except for the paint.
