TJ--As I said before, I cut the arena out of a hill. Our place is ten acres and the house/barn/outdoor arena sit on the road. I left the back 6 acres (which is fairly flat) for a hay field. The property's high spot is the middle and the back side (hay field) slopes gently down and then goes flat. The front of the property slopes quite abit and then levels out at the road. In order to have an arena and the barn down by the house we had to cut the arena out of the hill. The D-6 bulldozer was $115/hr so I just wanted him to cut out the hill and push the dirt somewhat level. I went in with a blade and leveled it more before the winter and just wanted it to settle. Well, we have about 2 feet of topsoil and then a gravel pit! Between the rocks the size of a basketball and the gravel, the base was really level still by spring. We left the sub-base alone. I added 4" of base material to the outside. This compacted to about 2-3" of depth. Our arena is 198 feet x 66 feet. My wife rides English Dressage and this is the standard measurements. The center of the arena was 8" and compacted to about 6-7". The half line (half way between the center and the outside) was at 6". This way, the water at the center only had to travel 33 feet and dropped 4 inches in that time. We have had really good success with this drop. You could shoot the sub-base to the 1/8 slope and then you would only need to add the same amount of base all over the arena. With the rocks in the sub-base and a good solid foundation, we decided to add more base. The negative side is it took me over 500 tons of base material to get the slope, but we don't have rocks coming up (not much). I use concrete sand as the riding surface material. It is small, easy to move, and gives to the horse when riding on it. It also holds moisture really well when we do water it to keep down the dust. It doesn't blow away in our 40-50 mph wind, either. The big thing for us was that we have 2 gravel pits within a mile and another in about 5 miles. This way, we didn't have to have some trucking company truck it in for us and I could do as my schedule allowed. I would carry 8-9 tons a load and could put it where I wanted instead of having some big belly dump come in and dump in a line. We also use concrete sand in our indoor arena for the same reasons. The indoor and outdoor are set at about 2-3" deep. It varies with the amount and type of riding that is done. I will drag a harrow thru it one day and the next I will level it with a level I built from 3" railroad spikes and two I-beams. We lined the outdoor with railroad ties to keep the material in. It works great. They came from a bridge in Michigan and are REALLY heavy (full 8x10" and 10 feet long). I bought a landscape rake and go around every 4-5 weeks and pull the sand off from the railroad ties. If you want, I can send pictures of our arena. Let me know. Glad I could help. Mike
