Ferguson D-EO-20 rake.
Terry in WA
02-15-2003 22:41:44
Hi, I am looking for atleast one rear wheel for my Ferguson D-EO-20 rake. One of mine is totally rusted out. The other one can be salvaged. I would like to find an original wheel because the rake is very nice condition otherwise. Does anybody out there have a wheel they would be willing to part with. I can send pictures if needed to help identify the wheel. Thanks, Terry
Chuck, WA
02-17-2003 08:46:12
 Re: Ferguson D-EO-20 rake. in reply to Terry in WA, 02-15-2003 22:41:44
Terry..where in WA? I'm in the Tri-Cities area - close to Richland.
I have what I've been told is a Ferguson D-EO-20 rake, but the name plate is too scuffed to be sure. For now, not willing to part out. I got it free with some other implements I bought and it needs a fair amount of work. Haven't given up on it yet, and was hoping to get it going for this summer. It needs some welding on the 3-pt frame, some bearings replaced on the bar attachment points and maybe most serious, oneof the spoked wheels that the bars attach to has a broken spoke that needs welded.
Question...do you have a manual? Do you know if any parts ard available? What's your experience with it?
Thanks!
Terry in WA
02-17-2003 12:23:50
 Re: Re: Ferguson D-EO-20 rake. in reply to Chuck, WA, 02-17-2003 08:46:12
Chuck, Thank you for responding to my posting. I do have a parts manual and operator's manual. If you send me your address, I have a copy of the parts manual that I can send you.
I have only found rake teeth in abundant supply and they need to be adjusted individually to the rake to fit properly. Not too hard to do. Originally, the rake came with tools to do such things. The operator manual discusses it briefly. If your bearings are bad in the spoked wheels you can probably go to a bearing supply store and get a good replacement bearing. The spoke can be welded by somebody that knows what they are doing. When I contacted Massey-Ferguson they were of no help at suppling parts.
I live near Spokane WA. If you decide not to repair your rake let me know. I need atleast one good wheel off of it. I would be interested in the whole rake or just the wheels should you decide to part with it.
Thanks, Terry
Chuck, WA
02-17-2003 14:13:25
 Re: Re: Re: Ferguson D-EO-20 rake. in reply to Terry in WA, 02-17-2003 12:23:50
Terry...for the time being, I need to plan on keeping it and repairing since I haven't found an affordable alternative.
The previous owner had new spindles made and also already bought a supply of bearings, and gave me those along with the rake, so my main problem is getting the spoke welded, and also removing and repairing the bars - some of which have their mounting holes badly elongated from wear, and some of which are slightly bent.
One of my concerns is that perhaps something is out of alignment - possibly as a result of hitting something hard enough to bend the bars or frame - and caused the spoke to break since at least one other spoke has been welded at some time in the past. But, as I say, for now, I need to keep headed in that direction.
Sounds like you have a spare copy of the parts manual - if so, how much would you want for it. I understand from another old archived post that the parts manual and operator's manual are 16 pages each. I'm checking on that previous poster to see if he'll copy and send, but if that doesn't work out, would you be willing to copy and send - or at least parts of it - at my expense for copying and mail?
There's a fellow in Utah - goes by Jim. UT on this board, who has both a DEO-25 and a model 36, and has offered some help in response to my previous posts about it. If you search the archives of the Implement board on "Ferguson Side Delivery TRake" you'll see the discussion that took place on 10 Oct 02. You might post again and address it to Jim. UT and see if he has ideas.
I'd expect that you could find a substitute, unless you are wanting to restore it with original parts.
I'll send you my e-mail address by e-mail so we can stay in touch off-line.
Thanks!
J P ESTEP
08-13-2006 15:13:27
 Re: Re: Re: Re: Ferguson D-EO-20 rake. in reply to Chuck, WA, 02-17-2003 14:13:25
I have a D-EO20 that was given to me I have been using it for about two years with no problems. Today a bearing failed in one of the rake bars. Does anyone have a part number for a replacement bearing?
Thanks in advance! By the way the ole' rake waited till I was on the last row!
Mike Slusher
02-05-2007 18:25:41
 Re: Re: Re: Re: Ferguson D-EO-20 rake. in reply to J P ESTEP, 08-13-2006 15:13:27
Hello guys, I found one of these rakes and used it last year. My tag is also so worn, that I think this is the right number. It is basically a 7 foot pick up rake. It says Harry Ferguson on the tag. Is this what you guys have. I raked around 40 acres with it, and like the other fellow, on my last windrow one of my arms came loose on the drivers side. The whole pin or bolt came loose out of the wheel. Am I to understand that my local dealer will not be able to help me with my parts. Has anyone tried to weld these back in place? By the way I live in Virginia. And the little rake worked fantastic.
