Did I get a good deal?
Wes
02-16-2003 09:20:38
I bought what I think is a massey harris 3-14 plow last fall for $50. It didn't have shares on it so I used JD shares for the little plowing I did. Just last week I bought a 5-14 massey-harris plow for $100. All five shares are almost new plus it has two used shares. Was this a good deal. I only plan on using the 3 bottom behind my 47 JD A, the five bottom is for parts.
steve II JD4000
02-16-2003 19:54:25
 Re: Did I get a good deal? in reply to Wes, 02-16-2003 09:20:38
yeah you did good, but I got 2 plow for free.!!
one is 2 bottom HIC other one 3 bottom JD.
Okla/Kans Bill
02-16-2003 19:49:56
Id say ya stole them lol. My dad had 2 14s and As and it was all we could do to get them to pull a 2 14 in 1st gear where we lived, in the Kansas, missouri River Bluffs
Terry H
02-18-2003 13:47:24
 Re: Re: Did I get a good deal? in reply to Okla/Kans Bill, 02-16-2003 19:49:56
Trouble pulling 2-14's with a JD A? You guys must have been trying to plow granite!
Terry H
Tim(nj)
02-18-2003 14:51:04
 Re: Re: Re: Did I get a good deal? in reply to Terry H, 02-18-2003 13:47:24
You haven't plowed Hunterdon County New Jersey clay . . . . 4-16" is all a 4020 wants! An A would definitely struggle with 2-14" in some fields.
JRN
02-16-2003 18:59:11
Sounds like you did well on your purchases. Depending where you live and if it is spring or fall, the A will not quite be loaded enough in 2nd but will lug in 3rd with the 3 bottom.
Wes
02-17-2003 17:25:00
 Re: Re: Did I get a good deal? in reply to JRN, 02-16-2003 18:59:11
I live in Spangle washington. The soils here go from a silt to heavy clay with a little ash mixed in. Last fall I plowed a little with the 3 bottom in 3rd at about 6 inches. Didn't even know the plow was there.
rem
02-16-2003 15:07:39
You did good!! Keep the ole JD tuned up if you have heavy soil.
paul
02-16-2003 14:24:39
It all depends where you live. Old 4+ bottom plows are about worthless, they sell for scrap iron prices. Too big for the collectors, and plug up too bad for real farmers to use. Add no-till, and big old plows are unwanted. 1, 2, or 3 bottom plows can go $400 because of the collectors tho!
I'd say you got a good deal as you will get your money out of it! :)
--->Paul
JM
02-16-2003 14:43:43
 Re: Re: Did I get a good deal? in reply to paul, 02-16-2003 14:24:39
I bought a MH/MF(?) 3pt 3x14 for $150 about 2 years ago. Had all new wear parts and a fresh coat of paint. It is a "rigid" implement, i.e. your draft control is your only protection as far as I can see. There is no mechanism on the plow itself for "break away" protection.
JM
JM
02-16-2003 14:42:38
JM
