Hyd. cylinder for plow
Jody
02-19-2003 17:19:31
JOHN DEERE REMOTE HYD. CYL. PART #AA 5380 R.
Will this hyd. cylinder for on a JD modle 66-H plow? Is it the correct cylinder?
Thanks
paul
02-20-2003 05:30:11
 Re: hyd. cylinder for plow in reply to Jody, 02-19-2003 17:19:31
I do not know.
However, _most_ implements take a standard sized (length) cylinder with an 8" stroke. Most likely, that is what you need. The diameter of the cyl shaft, & of it's bore, is only related to how heavy the implement is - if your tractor gets it lifted, it's big enough - 3" is sort of a standard for bore, but varies with how heavy of a load. :) The important measurement is the stroke of the cylinder, and the basic standard is 8".
--->Paul
