#5 mower parts
Kirk
02-25-2003 20:14:18
I am in the process of restoring my grandfather's old JD #5 mower. I am curious what is still available for this mower. It has been sitting a long time. The gear box turns freely. My most immediate need is for a wheel bearing assembly. Does anyone know if these are readily available?
Monica Jimenez
10-04-2004 16:40:01
 Re: #5 mower parts in reply to Kirk, 02-25-2003 20:14:18
Hello!!!
I would like to purchase this machine
Cutters Mowers,Tillage eqp. side winder, Model 40bs,No. Serie 136018
If you have information about I aprrecite if you could send it
Thanks
Monica Jimenez
Monica Jimenez
10-04-2004 16:39:26
Hello!!!
I would like to purchase this mahine
Thanks
Monica Jimenez
Old Iron
02-26-2003 17:00:27
Kirk,
If you need the wooden pitman stick give me a shout.
Old Iron
Wes
03-01-2003 14:40:47
 Re: Re: #5 mower parts in reply to Old Iron, 02-26-2003 17:00:27
I was reading your follow up. I am also redoing a No. 5 mower to use and need the pitman arm. Are they readily available?
Wes
Kelly C
02-26-2003 04:56:38
third party image
JD has the parts you need. Bring your wallet though.
JD also has the parts and user manuals for this mower. I picked one up for mine. It shows how to hook it up to many different tractors and also all of the adjustments that you need for the mower. JD part # for the user manual is OMH10156-01jan56
Chris
02-26-2003 04:54:46
There are a lot of parts still available from mother deere. If not Almost every junkyard has them on there lot. I just got mine and am redoing it to use. They are good ole mowers. Thanks Chris
