CUTTING SORGUM
chuck
02-26-2003 16:10:48
I planted two one ac strips of silage sorgum to block off the view of a house that over looks my hunting field. It worked well and the deer beded down in it in the fall. But this spring I want to remove it and plant some more. What is the best way to cut it down. I have a 6ft brush hog but think it might be to think for it and make more of a mess. A friend sugested that i burn it and then plow it under. An ac is a lot to burn with no acess to water to control. ANY THOUGHTS ON THIS SUBJECT.
CHUCK
chuck
02-27-2003 16:48:46
 Re: CUTTING SORGUM in reply to chuck, 02-26-2003 16:10:48
Ok. Thanks guys I will give the brush hog a try. I planted it pretty think but got out to look at it today and most is broken to the ground so it might not be so bad. Thanks again.
chuck
Phil (VA)
02-27-2003 13:23:13
I plant sorghum also, for some of same reasons, and I always bush hog it and then plow it under.
mark
02-27-2003 06:23:02
Cows
scottAR
02-26-2003 18:47:50
It would be better for the soil to bush hog or disc the stalks down and then plow it under.
