Brillion cultipacker
Jack
03-01-2003 14:08:45
I recently came across a brillion cultipacker in good working condition except for no trnsport wheels. Does anyone have any ideas for mounting a set of wheels onto the packer so I can transport it? The packer is about 30 years old and is 8 feet wide. Thanks for your help.
Robert Collins
11-22-2004 15:35:37
 Re: Brillion cultipacker in reply to Jack, 03-01-2003 14:08:45
I also have a 4" Axle Brillion Cultipacker.
I am in the procvess of replacing some Rollers and would like to find an owners Manual or an instruiction sheet. Does anyone have any information?
Do you
03-02-2003 21:55:06
have a loader tractor? Pick it up with a chain and move it to the next field.
Robert in W. Mi.
03-02-2003 06:17:05
Just build a small "A" frame on each end "on top" of it, and put and axle there. (or spindles + wheels) Then when you turn the packer over it will be on wheels, turn it back and it will be-a-packing. It won't be hard to turn over, just push the tongue up and over. Next way, would to put a movable axle on it with a cyclinder to push it down to raise the packer when roading. Wish i could explain it better, but maybe this will give you some idea's. Robert
Jack
03-02-2003 15:52:12
 Re: Re: Brillion cultipacker in reply to Robert in W. Mi., 03-02-2003 06:17:05
Robert, thanks for the response, I like both your ideas, will try and see what works.
bruce
03-01-2003 14:39:37
i have one i use on yards...i just hook it to the tractor and pull it on the trailer to move it ... bruce
