Cultivator Spacing on field cult.
Chris
03-03-2003 20:38:38
What would be a good spacing for the shanks on a 7ft cultivator for a little field cultivatin. Thanks Chris
Hugh MacKay
03-04-2003 17:47:42
 Re: Cultivator Spacing on field cult. in reply to Chris, 03-03-2003 20:38:38
I have a setup manual for an IH 45 Vibra Shank. It shows 6, 8 and 10 inch spacing. It shows how to achive this on frame. There is a latout plan for each spacing.
paul
03-04-2003 13:51:42
Well, if you use 4" shovels, about 6" apart would be great. However, if you are trying to put this on one bar, you will just make a trash rake. You need to stagger them on 3 (or so) different beams, so they are 18" or more apart from each other.
--->Paul
Bill Becker
03-04-2003 06:24:25
I have a MInneapolis Moline field cultivator and the manual suggests 6" spacing for normal conditions and 9" spacing for heavy trash.
old fart
03-04-2003 00:55:44
Chris, the most common is six inch, that is on a conventional cultivator. If you are using danish tines or the old spring tooth with a spike tooth shovel you can go closer as long as you are not working in a trashy condition. If you go six and stagger the path they travel youshould be satsified. Good Luck, and do what you feel most comfortable with.
