BoomPole 3PH hoist ?
BlueLite
03-04-2003 19:16:13
Find it hard to find a 3ph hoist, how common are they and what's the going used price? Are they hard to make?
I'd like to use it to load my pickup or at slaughtering.
Thanks
Gary
03-05-2003 17:17:35
 Re: BoomPole 3PH hoist ? in reply to BlueLite, 03-04-2003 19:16:13
I have two. One of them is the conventional one that you use a top link with. I had to build it super long to get any lifting height . That presents the other problem of keeping the front end on the ground. I then built one where the boom itself attaches to the tractor where the top link goes. I then built a triangle to attach to the lift arms. It pivots at the lifting point on the boom, effectively doubling? ? the distance it lifts. No problems with the hydraulics lifting the load, generally. I made the attaching point for the lifting triangle movable on the boom pole. I haven't had to move it, though.
Gary
03-05-2003 17:17:29
BlueLite
03-05-2003 19:15:10
 Re: Re: BoomPole 3PH hoist ? in reply to Gary, 03-05-2003 17:17:29
Great idea!!! Attach the pole at the top link.
I guess the best way to see how it would work is to cut out pieces of cardboard to scale and see how the operation would work at the design stage.
paul
03-06-2003 05:28:07
 Re: Re: Re: BoomPole 3PH hoist ? in reply to BlueLite, 03-05-2003 19:15:10
This would act like many post hole diggers, they are designed to lift from ground level to about 5' high. Just raise the overall starting & ending points, and one would have a nice lift!
--->Paul
CCI
03-05-2003 14:59:36
$60-$100 jocky stuff
Jim.UT
03-05-2003 07:36:11
CAL Ranch stores around here carry King Kutter brand boom poles. They price them at $64.95. Recently they decided to quit carrying King Kutter so they've put them on clearance price at $48.95. I got mine at an auction for $30.
The CAL Ranch store in Ogden UT still has 7 or 8 of them. I didn't think their clearance price was that impressive. I've heard of other stores selling them for $50 every day.
I used mine to pick up a 14.9-28 tire and rim loaded with CaCL. Don't know what it weighed, but the pole had no problem with it.
Jerry D in NC
03-04-2003 21:25:50
The going rate around here for a "Hog Lift" is $50-$100 depending on the design. Not that hard to make. Let me know if you want pics of mine
BlueLite - Thanks Jerry, that'd be great!!!
03-05-2003 06:35:46
 Re: Re: BoomPole 3PH hoist ? in reply to Jerry D in NC, 03-04-2003 21:25:50
I'm at paradok_99@yahoo.com
I was thinking that maybe a telescoping pipe arrangement like one of those house post supports might work. They're good for 8 tons vertical, so I figure 2 tons when tilted at 45degrees on the 3ph.
paul
03-05-2003 14:13:53
 Re: Re: Re: BoomPole 3PH hoist ? in reply to BlueLite - Thanks Jerry, that'd be great!!!, 03-05-2003 06:35:46
Generally they are rated from 500 lbs to 1000 lbs, depending how tough a boom pipe & how much arch-work you put into it. Never seen a pipe carry 4,000 lbs on a side load, you might want to rethink that.
The other thing, how big of a tractor are you putting this on? whatever you hang on the back is balanced by the front end of the tractor. Don't know of many older under 50 hp tractors that can lift 4000 lbs with the 3point, or counter balance it with the front end that heavy.
If you need something that heavy, you better give more details of what you are planning, so people can help more.
--->Paul
BlueLite
03-05-2003 19:02:10
 Re: Re: Re: Re: BoomPole 3PH hoist ? in reply to paul, 03-05-2003 14:13:53
Yeah, I should have clarified.
I was refering to what the house support pipe could possibly handle at that angle without bending. I would probably weld a truss arrangement over the pipe to be safe but that wouldn't look too good. 900lbs I figure would be about tops what I would want to lift. The tractor is a IH434 which is actually a clone 424. Weighs in at 3600lbs or so soaking wet.
