861 matching implements
william persall
03-11-2003 08:24:46
I am buying a ford 861 with a mounted front loader. I am buying a front blade (with down pressure) as well. Looking for advice on proper sized implements. I live in central michigan on 120 acresof sandy soil. 55 acres rented the rest consist of small challenge fields, pine stands mixed forest, shrubs and open spaces. I plan on doing landscaping and wildlife habitat improvements. Considering brush hog, finish mower, boom, scoop, rototiller, disk, harrow, plow, might do some haying as well. Useful advice is appreciated.
Eric
03-16-2003 06:49:30
 Re: 861 matching implements in reply to william persall, 03-11-2003 08:24:46
Your 861 can easily handle a 7 foot finish mower, also a 7 foot sickle mower. It is a 3- plow tractor, the plow should have 14 inch bottoms. You can buy a good mounted disk at your local Tractor Supply store. Hope this info will help you.
william persall
03-18-2003 18:13:19
 Re: Re: 861 matching implements in reply to Eric, 03-16-2003 06:49:30
Thanks for the info.
Eric
03-16-2003 06:48:47
