Disc Harrow Drag
Ken
05-20-1999 13:04:51
I have a couple of 8 foot John Deere disc harrows with a single iron pipe for a drag. I am not very happy with the results because the soil remains uneven and too coarse. What are some other ideas for harrow drags?
MARK
05-22-1999 13:57:17
 Re: Disc Harrow Drag in reply to Ken, 05-20-1999 13:04:51
THE PIPE MIGHT NOT BE THE BEST DRAG TO USE.I HAVE FOUND THAT THE PIPE DOES NOT LET A LOT OF DIRT RIDED IN FRONT OF IT . I USE TWO 8X8 POST 11FT LONG PUT UP ON THE EDGE (LIKE IN A DIMOND SHAPE) WITH TO PICE OF ALL THARED BETWEEN THEM. ABOUT A FOOT A PART.THIS DOES A GOOD JOB A LEVELING THE GROUND. I PULL THIS BEHIND A 10FT DISK AND A 2 SECTION HARROW AND IT DID A GOOD JOB AT BRAKING UP THE GROUND AND LEVELING IT.
Paul Fox
05-20-1999 15:39:31
Lotta folks hitch a spike-tooth or a spring-tooth drag behind the disk harrow if the tractor they're using has the power to pull both. My brother uses a piece of pipe onto which he welded short (6-8") pieces of rebar as teeth, about every 6". The pipe is cut to match the width of the implement.
