Allis Chalmers Disk
Double R``
03-23-2003 05:58:23
I have a 8ft transport wheel disk. I need about 6 sets of spacers that go between the disk blades on the front gangs They each consist of two pieces to make one complete spacer. I question the reasoning for this and wonder if another brand of spacer would work. Appreciate any help locating these or your input or advice.
Brent
03-24-2003 10:20:12
 Re: Allis Chalmers Disk in reply to Double R``, 03-23-2003 05:58:23
I have a 12 or 14 foot AC disk that was cut down to 8. I got the "extra pieces" that the previous owner had cut off, including the spacers. Measure yours and maybe mine will work for you. Incidentally, I had mine out yesterday as I just repaired one of the "hangers" for the gangs as the bushing that holds it up had rusted away.
Tom
03-23-2003 19:11:16
I might be wrong but I heard one time that Athens plow Co. built the disc for AC,so if you have a Athens dealer close by you might check with them. Hope this helps
Tom
03-23-2003 19:10:50
Tim(nj)
03-23-2003 07:37:59
Measure your axle, then the length of a complete spacer assembly between disks. Agri-supply sells replacement spacers, if I recall correctly. They may have one that will work. Good luck.
