DISC BREAKER FOR FARMALL A
DAVID M
03-23-2003 18:38:04
I HAVE A 1946 FARMALL A.I HAVE RECEIVED LOTS OF HELP FROM THIS SITE FOR OTHER RELATED THINGS FOR THIS TRACTOR.I HAVE A DISC BREAKER WHICH WAS GIVEN TO ME WITH THIS TRACTOR AND I WAS TOLD IT MOUNTS UNDERNEATH THE TRACTOR.COULD ANYONE TELL ME IF THIS IS RIGHT AND IF NOT POSSIBLEY TELL ME WHAT WOULD BE CORRRECT.I DO NOT KNOW WHAT MODEL THIS BREAKER IS AND IT IS NOTHING LIKE WHAT I HAVE SEEN ON SIMILAR TRACTORS LIKE THIS WHICH I BELEIVE ALL HOOKED FROM THE REAR. THANKS.
Gary-Miss
03-24-2003 18:09:12
 Re: DISC BREAKER FOR FARMALL A in reply to DAVID M, 03-23-2003 18:38:04
I have a single bottom disc plow that mounts on the front of the final drive housings. It is lifted by a long arm at the front. One thing to be certain of is that you must set the right fornt wheel out the distance of the "land", so that your right front tire travels in the old furrow and the right rear travels in the new furrow. They do pretty good on small plots.
